What are First Principles?
Definition of First Principles: First principles refer to the fundamental, foundational truths or assumptions that cannot be broken down further. They are the basic building blocks of reasoning, derived from direct observation or undeniable facts. By reasoning from first principles, one strips away assumptions, conventions, or biases to understand a problem or concept at its core, enabling innovative or clear solutions.
Example:
Consider designing a new electric car battery. Instead of starting with existing battery designs and tweaking them, you reason from first principles:
  • Step 1: Identify the core goal: Store energy efficiently for long-range driving.
  • Step 2: Break it down to fundamentals: A battery stores energy through chemical reactions. Key components include electrodes, electrolytes, and a casing. Energy density depends on the materials used (e.g., lithium, cobalt).
  • Step 3: Question assumptions: Why use expensive cobalt? Are there alternative materials with similar or better properties? Can the casing be lighter yet durable?
  • Step 4: Rebuild: Research shows lithium-sulfur could offer higher energy density at lower cost. A new casing material, like a lightweight composite, could reduce weight.
By focusing on fundamental truths (energy storage, material properties) rather than industry standards (cobalt-based batteries), you innovate a potentially cheaper, more efficient battery. This approach, famously used by Elon Musk for SpaceX’s rocket cost reduction, avoids incremental thinking and drives breakthroughs.
Credit: Grok
