This is a small device you can put on an old treadmill to collect and sent data to health and fitness devices and applications. Convert your old treadmill, PaceMaster ProSelect, into a smart treadmill.
ConfigurEZ
RUNN…
B3720F4B ANT:134987
Firmware: 3.5.3
Button Functions
2 taps, turns on/off
| State | LED |
| On | Right LED lit, ANT+ radio is active |
| Off | No LED lights lit |
LED Status
| LED | State |
| Right | On when ANT+ radio is active |
| Middle | On when USB powered |
| Left | On when BLE is connected |
Strip Detection
Left & right LEDs toggle opposite each other when a strip is detected as it passes under the sensors. This mode is used for making sure Runn is set up properly. The LEDs will toggle for approximately 1 minute.
- Double press the white button → right LED should turn on
- Single press the white button → left & right LEDs will toggle if Runn is picking up the sensor strips
How do I turn my Runn on/off?
A: You can turn on/off the ANT+ radio in your Runn, but BLE is always advertising at a very low power until it is connected to an app like GymTrakr or Zwift. The right LED indicates if the ANT+ radio is on/off, lit is on and not lit is off. The left LED indicates if BLE is connected or not, lit is connected and not lit is not connected. You can find more information on the LEDs here.
Buy this from Amazon, cost you nothing and make money
