Overview of Controls on the Riese & Müller Charger4 GT Vario
Riese & Müller Charger4 GT Vario – Quick Controls (190 words)
Turn On: Press the On/Off button on the Bosch LED Remote (left handlebar). LEDs light up; system is ready.
Pedal Assist: Yes – 4 modes (Eco, Tour, Sport, Turbo).
Use + / – buttons on the LED Remote to change.
  • Green = Eco
  • Blue = Tour
  • Yellow = Sport
  • Red = Turbo
    Motor helps only when you pedal (pedal-assist, no throttle).
No Throttle – This is a pedelec (Class 1/3), max 25 km/h (EU) or 20/28 mph (US), assist cuts at limit.
Change Gears: Twist the Enviolo shifter on the right grip:
  • Forward (clockwise) → harder gear (faster)
  • Backward (counterclockwise) → easier gear (climbing)
    Stepless CVT – shift anytime, even stopped.
Lights: Press the light button on LED Remote.
Walk Assist: Hold – button while pushing.
That’s it – pedal to go, twist to shift, buttons to adjust power. No throttle, just smart pedal assist.
Details about Controls on the Riese & Müller Charger4 GT Vario
The Riese & Müller Charger4 GT Vario is a premium trekking e-bike equipped with the Bosch Smart System, featuring a Performance Line CX motor (85 Nm torque), a 750 Wh integrated PowerTube battery, Enviolo Trekking 380 CVT hub gearing, Gates Carbon Belt Drive, and Magura hydraulic disc brakes. Its controls are designed for intuitive, distraction-free operation, emphasizing comfort and versatility for commuting, touring, or light off-road use. The setup includes an integrated cockpit with the Bosch LED Remote (primary control unit), optional Kiox 300 display, Enviolo twist shifter, brake levers, and additional toggles for lights and suspension. All controls are thumb-accessible while keeping hands on the handlebars (typically a Humpert Ergo XXL or Satori Custom model).
Below, I’ll break down the main controls and how they work, based on the bike’s standard configuration.
1. Bosch LED Remote (Main Control Unit)
  • Location: Mounted on the left side of the handlebar, just below the Kiox 300 display (if equipped) or as a standalone unit. It’s compact, L-shaped, and ergonomic for thumb operation.
  • Key Functions:
    • Power On/Off: Press the dedicated On/Off button (usually a circular rocker) to activate the system. The bike powers down automatically after inactivity.
    • Assist Modes: Cycle through four modes—Eco (low support for efficiency), Tour (balanced for everyday riding), Sport (higher power for faster paces), and Turbo (maximum boost for hills or headwinds)—using the plus (+) and minus (-) buttons. The LED ring changes color to indicate the mode: green (Eco), blue (Tour), yellow (Sport), red (Turbo). Modes can be customized via the eBike Flow app (Bluetooth-connected) for personalized power delivery.
    • Walk Assist: Hold the minus (-) button while pedaling slowly to engage low-speed motor assistance (up to 6 km/h) for pushing the bike uphill or through tight spaces. Release to stop.
    • Lights: A separate button toggles the integrated Supernova front/rear lights (with daytime running light mode). The LEDs confirm activation with a flash.
    • Additional Features: Ambient light sensors auto-adjust LED brightness. It pairs with the eBike Flow app for GPS navigation, ride tracking (e.g., distance, elevation), over-the-air updates, and theft protection (smart lock). If the Kiox 300 display is present, it shows detailed info like battery range, speed, and odometer; otherwise, the Remote’s LEDs provide basics.
  • How It Integrates: The Remote communicates wirelessly with the motor, battery, and display for seamless operation. It’s highly visible in all lighting and reduces glove interference.
2. Enviolo Trekking Shifter (Gearing Control)
  • Location: Right handlebar grip—a twist-style shifter integrated with ergonomic Ergon or similar grips.
  • Key Functions:
    • Stepless CVT Shifting: Twist forward (clockwise) to increase gear ratio for higher speeds/efficiency on flats; twist backward (counterclockwise) to decrease for easier pedaling on climbs. The Enviolo 380 hub provides infinite variability (380% range) without clicks or pauses, allowing shifts under load—even at a standstill—thanks to its torque-sensing design paired with the Bosch motor.
    • Gear Indicator: A small LED or analog dial on the shifter shows your current ratio (e.g., 0-10 scale, where lower numbers are easier gears). It syncs with the Bosch system for optimal motor performance.
    • Automatic Mode (Optional): If equipped (configurable via app or shifter toggle), the system auto-adjusts based on cadence, speed, and terrain for hands-free shifting—ideal for relaxed touring. Manual override is always available.
  • How It Works with the Bike: Combined with the Gates belt drive, it ensures quiet, maintenance-free operation (no chain lube needed). The motor adapts power output to your selected ratio, making transitions smooth and efficient.
3. Brake Levers
  • Location: Standard hydraulic levers on both handlebars (Magura MT4/MT5 or MT-C with optional ABS).
  • Key Functions:
    • Front/Rear Braking: Squeeze the right lever for front brake, left for rear. Progressive hydraulic discs provide strong, modulated stopping power (up to 203 mm rotors) with minimal effort.
    • Motor Cut-Off: Braking automatically disengages motor assist for safety and regenerative energy recovery (recharges the battery slightly).
    • ABS Integration (Optional): If fitted, sensors prevent wheel lock-up on slippery surfaces; no separate control needed—it’s always active.
  • How It Feels: Levers are ergonomic with reach adjustability, suitable for various hand sizes.
4. Other Controls
  • Integrated Cockpit/Display (Kiox 300, Optional): Mounted centrally on the adjustable Satori stem. Touchscreen shows navigation, fitness data, and battery status. Swipe or tap to access maps (via app sync); it rotates for off-bike viewing.
  • Suspension Toggle: A small lever on the left handlebar adjusts the SR Suntour Mobie 34 fork (100 mm travel) and Suntour Comfort seatpost between lockout (for efficiency) and full plush (for rough terrain).
  • Bell/Horn: Standard ding bell on the left; some configs include a louder horn button.
  • App Connectivity: All controls link to the eBike Flow app on your phone (iOS/Android) for deeper customization, like setting speed limits or tracking routes.
Tips for Use
  • Startup Routine: Power on via LED Remote, select Eco/Tour for city rides, and twist shifter to mid-range for a balanced start.
  • Battery Management: The 750 Wh pack offers 50-100+ km range (depending on mode/terrain); monitor via Kiox or app.
  • Maintenance: Controls are weather-sealed (IP65 rating), but clean the shifter periodically for smooth twisting.
  • Customization: Use the Riese & Müller configurator or Bosch app to tweak setups. For hands-on learning, refer to the Bosch eBike Flow app tutorials or dealer demo.
This setup makes the Charger4 GT Vario feel effortless and high-tech, prioritizing safety and enjoyment.
Riese & Müller Charger4 GT Vario Configuration F01005_040232081340
This code identifies a specific custom build of the Charger4 GT Vario, Riese & Müller’s premium trekking e-bike designed for everyday commuting, touring, and light off-road use. The prefix F01005 denotes the base model variant (Charger4 GT Vario with Enviolo Trekking CVT hub gearing and Bosch Smart System). The suffix _040232081340 encodes detailed options like frame size, color, components, and accessories, generated via the R&M online configurator. Exact decoding requires dealer access or the configurator tool, but based on similar codes (e.g., F01005_0402210814131 for 49 cm black frame), here’s the likely breakdown:
Core Specifications
  • Model: Charger4 GT Vario (GT = high-end with continuous lights, suspension fork, and dropper post options).
  • Frame Size: 50 cm (inferred from “04” in similar codes; confirm via dealer for fit—suits riders ~170-185 cm).
  • Color: Urban Black Matt or Graphite Grey Matt (common for “23” codes; premium powder-coated aluminum frame).
  • Motor: Bosch Performance Line CX Gen5 (85 Nm torque, 250W, up to 25 km/h assist).
  • Battery: Integrated PowerTube 750 Wh (50-120 km range, depending on mode/terrain; removable via app-unlock).
  • Gearing/Drivetrain: Enviolo Trekking 380 CVT hub (stepless shifting, 380% range) with Gates CDX Carbon Belt Drive (maintenance-free).
  • Suspension: SR Suntour Mobie 34 fork (100 mm travel, adjustable) + suspension seatpost (e.g., SR Suntour NCX, 40 mm travel).
  • Brakes: Magura MT5 hydraulic disc (203/203 mm rotors; optional ABS).
  • Wheels/Tires: 28" Alex rims with Schwalbe Marathon Supreme 40 mm tires (puncture-resistant, reflective sidewalls).
  • Cockpit/Display: Bosch Kiox 300 color display + LED Remote (touchscreen for navigation, app integration via eBike Flow).
  • Lights: Supernova M99 Mini front/rear (daytime running lights, always-on GT setup).
  • Saddle/Handlebar: Ergon SM E-Pack saddle + Ergon GE1 grips; adjustable stem.
Additional Likely Options (Based on Code Patterns)
  • Frame Type: Trapez (step-through) or High-Step (diamond; “32” suggests High-Step).
  • Extras: RX Chip (anti-theft GPS tracker), kickstand (helix), rear rack (MIK-compatible, 25 kg capacity), fenders/mudguards.
  • Weight: ~26-28 kg (without pedals).
  • Price Range: €5,500-€7,000 (varies by region/extras; US ~$6,000-$7,500).
  • Max Load: 140 kg (rider + cargo).
This setup emphasizes comfort (suspension, belt drive) and tech (Bosch ecosystem for app-based customization). For precise details, enter the code in the R&M configurator (riese-mueller.com/en-us/configurator/) or contact a dealer—they can export the full spec sheet. If it’s a production build code, track status at r-m.de (homepage > Production Status).
