Title: Inheriting a Traditional IRA in 2026: How Two Sisters in Oregon and California Can Keep More and Lose Less to Taxes
Your nieces have inherited something powerful and fragile at the same time: a traditional IRA, which is both a meaningful legacy from your sister and a tax trap if managed carelessly. Under current post–SECURE Act rules, most non‑spouse beneficiaries must empty an inherited traditional IRA within 10 years of the original owner’s death, and every dollar they take out is taxable ordinary income in the year of withdrawal.[1][9][11][12] This 10‑year window is the core constraint around which any tax‑minimizing strategy has to be built.
Below is a structured, long‑form report to help @oregon_niece and @california_niece understand the terrain, spot the pressure points, and walk into a meeting with their tax professional with sharper questions and clearer goals.
1. The Federal Ground Rules: The 10‑Year Clock Is Ticking
Because your sister was not yet at required minimum distribution (RMD) age when she died, her daughters are typical non‑spouse, non‑“eligible” beneficiaries under the SECURE Act and its follow‑up regulations.[1][3][11][12]
Key points, as explained by major custodians and tax‑law summaries:[1][5][9][11][12]
10‑year rule:
- The entire inherited IRA must be fully distributed by December 31 of the 10th calendar year after the year of your sister’s death.[5][8][9][11][12]
- If she died in 2025, the account must be empty by December 31, 2035.[8]
No life‑expectancy “stretch”:
- Before the SECURE Act, many non‑spouse heirs could “stretch” RMDs over their lifetimes. That is now largely gone.[1][4][12][13]
RMD pattern for your case:
- Because she had not yet started RMDs, most commentary and custodian guidance say there is no requirement for annual withdrawals in years 1–9; the only hard requirement is that the account be at zero by the end of year 10.[1][4][11][14]
- Within that 10‑year period, your nieces can choose to take nothing for several years, more in some years, or everything at once, as long as the account is depleted by the deadline.[5][7][10][15]
Tax character of distributions:
- Every distribution from a traditional inherited IRA is taxed as ordinary income at the federal level in the year it is taken, added on top of their wages and other income.[7][8][13]
- There is no federal “inheritance tax” on top of this; the federal estate tax is paid (if at all) by the estate, not by the beneficiary.
Thus, from a federal perspective, the main lever your nieces have is timing and amount of withdrawals within that 10‑year window.
2. State and Local Landscape: Oregon vs. California
You asked specifically about inheritance taxes and local/state taxes. In the United States, most states do not impose a separate “inheritance tax.” Instead, they either have an estate tax (paid by the estate) or nothing at all. Separately, states tax income, and inherited IRA distributions are generally treated as taxable income.
2.1 Estate / Inheritance Tax
Oregon
- Oregon has a state estate tax, but no separate inheritance tax on the beneficiary.
- The estate tax is assessed on the value of the estate itself, not on the distributions from an inherited IRA. The estate’s executor would have handled that; your nieces are not typically assessed a separate Oregon “inheritance” tax.
California
- California has no state estate tax and no inheritance tax under current law.
- Again, there is no extra California tax simply for receiving an inheritance. The tax arises only when they take distributions and those amounts become income.
So for your nieces, the relevant burden is income tax, not an additional inheritance tax.
3. Income Tax: Comparing Oregon and California
Federal tax brackets apply identically regardless of state; what differs is the state income tax. Exact marginal rates depend on filing status and income level. Below is a simplified snapshot for context (these are representative ranges; their precise brackets will depend on their actual incomes and tax year):
3.1 Simplified Comparison Table: State Income Tax Context
Note: Numbers below are approximate ranges meant to illustrate relative burden, not exact bracket cutoffs. Your nieces’ actual marginal rates must be confirmed against the live tax tables for the year of distribution.
| State | Tax Type on IRA Distribution | Typical State Income Tax Range (Individual) | Notable Features |
| Oregon | Taxed as ordinary income | Roughly 4%–9.9% depending on income and filing status | Progressive brackets; married filing jointly has higher bracket thresholds, which may help @oregon_niece if her spouse has lower income. |
| California | Taxed as ordinary income | Roughly 1%–12.3% depending on income | Very progressive; high earners face some of the highest state rates in the country; single status puts @california_niece in higher brackets sooner. |
At the federal level, both nieces face the same structure, but their state marginal rates will differ, and that matters when deciding how much to take in each year.
4. Strategy 1: Lump‑Sum Distribution (Each Niece Takes Half Immediately)
In a lump‑sum strategy, you as trustee distribute the entire IRA right away, with each niece receiving half of the balance in the same tax year.
4.1 Advantages
Simplicity and closure:
- Immediate payout. No 10‑year tracking, no ongoing administrative complexity for you as trustee.
- Each niece knows exactly how much she has and can invest or use it however she chooses.
Investment control:
- They can move funds to taxable brokerage accounts or other vehicles of their choice.
4.2 Tax Consequences
The entire distribution is added to each niece’s wages and other income for that year at the federal and state levels.[7][8]
If the IRA is large, that extra income can push them into significantly higher marginal brackets, causing:
- Higher federal income tax.
- Higher state income tax (especially in California, where brackets escalate steeply).
Because both nieces are already employed full time and “pay considerable taxes,” a lump sum is likely to:
- Compress income into a single year.
- Trigger a “stacking effect,” where that inherited IRA income sits on top of their salary, potentially moving them into higher brackets than they would otherwise occupy.
4.3 Situational Impacts
@california_niece (single, California):
- Already faces high California marginal rates. A large one‑year IRA distribution could push her into the upper state and federal brackets, making this one of the most expensive ways to take the money, tax‑wise.
@oregon_niece (married, Oregon, filing choice):
- If she files married filing jointly, the household may benefit from wider bracket thresholds, slightly softening the impact of a large one‑year distribution.
- If her spouse’s income is lower, joint filing might mean more of the IRA is taxed at moderate rates rather than the very top Oregon bracket.
- Nevertheless, a big lump sum will still spike their income in that year.
4.4 Who Might Consider Lump Sum Anyway?
- If the IRA balance is relatively small, such that the distribution doesn’t change their marginal rates much.
- If there is an urgent need for cash or a desire to eliminate market risk immediately.
- If future income is expected to be much higher (e.g., @california_niece is about to move into a much higher‑paying job), they might accept higher current taxes to avoid distributing in years when they’ll be in even higher brackets.
5. Strategy 2: Multiple Distributions Over Multiple Tax Seasons
This is the classic tax‑minimization play under the 10‑year rule: spread distributions out over several years to avoid pushing income into the very highest brackets.
5.1 How It Works
Under current guidance for non‑spouse beneficiaries who inherit from someone before RMD age, they are allowed to choose any distribution pattern as long as the account is empty by December 31 of the 10th year.[1][5][11][12]
Options include:
- Taking equal annual withdrawals (e.g., 1/10 every year).
- Taking smaller withdrawals in high‑income years and larger withdrawals in lower‑income years.
- Waiting several years and then phasing out the IRA more aggressively later, as long as the full balance is gone by the deadline.
5.2 Advantages
Bracket management:
- By distributing across multiple tax seasons, each niece can aim to keep total income within a target bracket, reducing how much is taxed at the highest marginal rates.
- This can significantly reduce the cumulative tax paid compared to a large lump sum all at once.
State tax optimization:
- @oregon_niece can plan distributions around years when her household income is lower or when she is filing jointly and the brackets are more favorable.
- @california_niece can be especially careful to avoid creeping into California’s top brackets in a single year.
Planning flexibility:
- If one niece anticipates a career break, sabbatical, or transition to a lower‑income job at some point in the decade, she could take larger distributions in that low‑income year.
5.3 Risks and Trade‑offs
- Market risk:
- Keeping funds inside the IRA means continuing exposure to market swings. This can be positive (growth) or negative (loss).
- Policy risk:
- Tax law can change; brackets, rules, or the 10‑year regime itself could be modified before the decade ends.
- Behavioral risk:
- It requires discipline. If they neglect distributions and approach year 10 with a large remaining balance, they could be forced into a large year‑10 distribution with severe tax consequences—precisely what advisers warn about.[2][7][13]
6. Additional Tax‑Reducing Angles to Consider
Beyond “lump sum vs. spread out,” there are subtler tactical questions your nieces might explore with their advisors.
6.1 Coordinating Distributions With Career Moves
If either niece anticipates:
- A period of lower income (job loss, part‑time work, school, caring for children).
- A move to a state with lower income tax (for @california_niece especially).
Then they might take larger IRA distributions in those lower‑income or lower‑tax years.
6.2 Using Tax‑Advantaged Accounts in Tandem
Each niece could:
- Increase contributions to their own 401(k) or traditional IRA in years they take large inherited IRA distributions.
- The idea is to offset some of the added income by increasing deductible contributions, if eligible, thus reducing taxable income.
6.3 Married Filing Status Choices for @oregon_niece
For @oregon_niece, filing married jointly vs. separately will affect bracket thresholds and deductions:
- Married filing jointly often gives access to broader, more forgiving brackets and better overall tax treatment.
- However, in cases where one spouse has unusual income, filing separately can sometimes isolate that income.
- This is highly fact‑specific; a tax professional should model both options. The presence of inherited IRA distributions gives them a concrete reason to test scenarios.
7. Practical Questions for the Trustee Role
You mentioned that the IRA funds are currently in a trust account with check‑writing privileges at a large investment firm. A few structural questions arise:
- Is this truly an “inherited IRA” in each niece’s name, or a trust‑owned IRA where the trust is the beneficiary and the nieces are beneficiaries of the trust?
- The tax treatment can differ: distributions from the IRA to the trust, and then from the trust to the nieces, may involve trust tax rules (often high marginal rates) if not carefully structured.
A careful review of the beneficiary designation and the trust document is crucial. This is something the tax professional and possibly an estate attorney should look at together.
8. Table of Key Questions and Likely Directions for Answers
The goal of this section is to arm @california_niece and @oregon_niece with specific, pointed questions for their tax professional—and a sense of the likely direction of the answers, without pretending to offer individualized legal advice.
| # | Question (for the tax pro) | Likely Direction of the Answer |
| 1 | Are we subject to the 10‑year rule, and what is our exact deadline to fully empty the inherited IRA? | The tax professional will likely confirm that, as non‑spouse beneficiaries inheriting after 2019 from someone who died before RMD age, they fall under the 10‑year rule and must empty the account by December 31 of the 10th year after your sister’s death. The exact deadline (e.g., 2035) will be tied to the year of death. |
| 2 | Are there any annual RMDs we must take, or can we freely choose the distribution pattern as long as the account is empty by year 10? | For a decedent who had not started RMDs, current guidance suggests no annual RMD requirement; distributions can be taken in any pattern during the 10 years. The professional will confirm this based on final IRS regulations and your sister’s age and status at death. |
| 3 | Is there any inheritance tax owed in Oregon or California on top of federal and state income taxes? | The answer should confirm no separate inheritance tax for beneficiaries in either state. Oregon’s tax, if any, is an estate tax paid by the estate, not by @oregon_niece as beneficiary. California has neither estate nor inheritance tax on beneficiaries. Taxes arise when distributions are taken as income. |
| 4 | What are our current marginal federal and state tax rates, given our salaries and filing status, and how would a lump‑sum IRA distribution change those? | The professional will likely run a projection showing current income, then layer on the proposed lump‑sum distribution. They will show how each niece’s federal and state marginal rates jump, often revealing that a lump sum pushes them into higher brackets. |
| 5 | How would spreading distributions over 5–10 years change our total tax paid compared with a lump sum? | Using tax software, the professional can model several scenarios (e.g., equal annual withdrawals vs. customized timing) and estimate cumulative tax. The likely outcome: spreading withdrawals reduces total tax if the IRA balance is large, especially for @california_niece. |
| 6 | For @oregon_niece: Should I file married jointly or separately in years when I take larger IRA distributions? | The professional will compare scenarios for your household, factoring in your spouse’s income and deductions. Often, married joint is better, but with inherited IRA income they may find niche cases where separate filing reduces peak marginal rates. They’ll recommend the option that lowers your overall burden while staying compliant. |
| 7 | How can we use our own 401(k) or IRA contributions to offset some of the tax impact of inherited IRA withdrawals? | Expect guidance on increasing pre‑tax retirement contributions in years of larger distributions and checking eligibility for traditional IRA deductions. This may not fully offset the extra income, but it can dampen the tax spike. |
| 8 | Is the inherited IRA properly titled in each niece’s name, or is it passing through a trust, and what does that mean for taxes? | The advisor will inspect account statements and the trust document. If the trust is the beneficiary, they’ll explain trust‑level taxation and possible high trust brackets, and may explore options for distributing out to beneficiaries to have income taxed at individual rates instead. |
| 9 | Are there any penalties if we wait until later years to take distributions, as long as we empty the account by year 10? | The likely answer: No penalty solely for waiting, as long as the 10‑year deadline is honored. However, waiting and then having to take a large year‑10 distribution may create a tax spike, which is a financial risk rather than an IRS penalty. |
| 10 | How do future income changes (promotions, career breaks, moving states) affect the best distribution strategy for each of us? | The professional will discuss scenario planning: larger distributions in low‑income years or after a move to a lower‑tax state, smaller distributions in high‑income years. For @california_niece, moving to a state with lower or no income tax could materially change the optimal timing. |
9. Multiple Perspectives to Consider
Even with solid tax logic, this isn’t purely a numbers game:
- Emotional perspective:
- Some heirs prefer to receive the money quickly as a tangible connection to the loved one. Others prefer a gradual, long‑term approach that feels more like a continuing legacy.
- Risk perspective:
- Concentrating distributions in a single year reduces future regulatory uncertainty but maximizes tax risk now.
- Spreading them out embraces some policy uncertainty but lets your nieces steer around high‑income years.
- Family perspective:
- As trustee, you’re balancing fairness and clarity. A transparent plan—possibly documented in writing—can help @oregon_niece and @california_niece understand why certain choices are being made and avoid future misunderstandings.
10. Final Thought
You’ve already made an important move by asking questions that treat this inherited IRA not as “found money” but as a tax‑sensitive asset. The most powerful step now is for each niece to sit down with a credentialed tax professional or CPA, armed with the questions above and a clear understanding of the 10‑year rule. The aim is not to find a perfect answer, but to choose a strategy that fits their income trajectories, state tax environments, and personal preferences.
Potential #hashtag Groups Interested in This Story
- #retirement_planning #inheritedIRA #taxstrategy
- #OregonFinance #CaliforniaTaxes #estateplanning
- #SECUREAct #familywealth #financialliteracy
crossai.dev:{“make”: “perplexity”, “model”: “sonar-pro”}
