Recommended 32 Spoke 700C Disc Brake Wheelsets for Cruzbike S40
The Cruzbike S40 uses a standard road/gravel wheel configuration with 12x100mm front thru-axle (non-drive, so no freehub needed) and 12x142mm rear thru-axle (drive side on the S40’s front fork, requiring a freehub). Any compatible off-the-shelf wheelset can be installed by swapping the “front” and “rear” wheels to match the freehub placement. I’ve focused on wheelsets with confirmed 32 spokes (or options for it) based on product specs, avoiding ones where you’d have to count in photos. These are suitable for road, light gravel, and endurance riding on the S40.
I prioritized models with tubeless compatibility, modern axle standards, and Shimano/SRAM freehub bodies (matching most S40 builds). Prices are approximate USD as of 2026 and can vary by retailer. For custom builds, many wheel builders (e.g., Light Bicycle) allow selecting 32-hole hubs/rims. If you’re over 200 lbs or doing heavy touring, 32 spokes provide good durability without excess weight.
| Brand/Model | Spoke Count (Front/Rear) | Material | Rim Width (Internal/External) | Depth | Weight (Set, Approx.) | Price (Approx.) | Axle Specs | Freehub Compatibility | Key Features | Notes for S40 |
| Cruzbike Stock (or Take-Offs) | 32/32 (3-cross lacing) | Aluminum | ~19-21mm internal / 25mm external | ~28mm | ~1,800-2,000g | $200-300 (used take-offs often cheaper) | 12x100mm F, 12x142mm R | Shimano 11-speed (or similar) | Tubeless ready, aero profile, non-machined sidewalls for disc-only | Direct fit; stock on S40 with Maxxis Re-Fuse 700x32c tires. Users report 7,000+ miles durability for lighter riders (~150 lbs). |
| DT Swiss ER 1600 Spline 32 | 32/32 | Aluminum | 20mm internal / 24mm external | 21mm | ~1,600g | $500-600 | 12x100mm F, 12x142mm R | Shimano/SRAM 11/12-speed | Tubeless ready, straight-pull spokes for stiffness, road/gravel optimized | Excellent for S40’s FWD torque; lightweight upgrade over stock with better rolling efficiency. Often praised for reliability in forums. |
| Quality Wheels Value Series (Shimano Hub) | 32/32 | Aluminum | ~17-19mm internal / 23-25mm external | 20-25mm | ~1,900g | $200-350 | 12x100mm F, 12x142mm R (thru-axle options) | Shimano 11-speed | Double-wall rims, DT Swiss spokes/nipples, all-black finish, tubeless compatible | Budget-friendly repair/upgrade staple; solid for everyday S40 use. Matches stock spoke count for consistent feel. |
| Light Bicycle Airia 32 (Customizable) | 32/32 (option) | Carbon | 23mm internal / 30mm external | 32mm | ~990g | $1,100+ | 12x100mm F, 12x142mm R | Shimano/SRAM/XDR | Aero-optimized, tubeless, lightweight racing build, customizable spokes (Sapim CX-Ray available) | Great aero/performance boost for S40; select 32 holes at build for durability. Suited for faster road rides, less ideal for rough gravel. |
| Mavic CXP Elite (Built with Shimano 105 Hub) | 32/32 | Aluminum | ~17mm internal / 22mm external | 21mm | ~1,700g | $300-400 | 12x100mm F, 12x142mm R (QR or thru) | Shimano 11-speed | Clincher/tubeless, DT 2.0mm spokes, quick-release or thru-axle | Reliable entry-level upgrade; users note good balance of weight and strength for recumbents like S40. |
| KinLin XC-279 (with Chosen Hubs, as on V20c/S40) | 32/32 | Aluminum | ~19mm internal / 24mm external | 27mm | ~1,800g | $250-350 | 12x100mm F, 12x142mm R | Shimano/SRAM | Tubeless ready, durable for mixed surfaces, used on Cruzbike models | Essentially the stock spec; easy to source as a replacement set. Good for maintaining OEM feel on S40. |
Additional Tips
- Where to Buy Without Counting Spokes: Shop at sites like Modern Bike, Jenson USA, or Merlin Cycles—they list spoke counts in specs (e.g., filter by “32-hole”). eBay/Amazon often specify in titles, like “DT Swiss G540 32-Hole.” Avoid generic photos; use search terms like “32 spoke 700c disc wheelset” on those sites.
- Customization: If no off-the-shelf matches your needs (e.g., deeper carbon for aero), go custom via Light Bicycle or a local builder. They let you pick 32 spokes for better load handling on the S40’s front-drive setup.
- Performance Notes: 32 spokes strike a balance for the S40—stiff enough for torque but not overly heavy. For heavier riders or rough terrain, consider 36 spokes on the drive wheel (S40 front). Always check freehub (e.g., Shimano HG for 11-speed) and rotor mount (Center Lock or 6-bolt) against your setup.
- User Feedback: In Cruzbike communities, 32-spoke wheels hold up well for general riding, with some upgrading to carbon for weight savings while keeping the count for reliability. If you share your budget, weight, or terrain (e.g., road vs. gravel), I can narrow this further.
